3 Way Tipping Trailer Hinges
   / 3 Way Tipping Trailer Hinges #1
Artisan
Veteran Member
Monrovia, California
Kubota BX25
Does anyone have a link for 3 Way Tipping Trailer Hinges?
The ball and socket variety?
TIA!
   / 3 Way Tipping Trailer Hinges #2
I wonder if you could use a trlr. ball (4) and just the right size and legnth pipe, maybe sch. 80 for the socket.
You could drill a small hole just in the right spot for a "keeper" pin that would keep your pinned pair of hinges the pivot point. This leads to the next question of the cyl. mounting and location. From what I remember seeing, the cyl. is right in the middle of the body and usually a vertically mounted telescoping type. Show us what you find.
Yes, and thnk you Rusty for the reply.
I do not see that it is rocket science BUT,
I still want to find them and "shop" them..
If I were to do it, I would probably go w/ a
2.125" ID DOM tube perhaps...
   / 3 Way Tipping Trailer Hinges #4
What's your application? At first what came to mind was the smallerish trailer, 2 axle, towed by a tractor, I remember seeing orange color ones at the JD dealer that did a lot of work with the golf courses. But now I remember on some of the "town" snowplow trucks up here have a crazy forward and sideway dumping bed to feed salt sand to the spinner. If I get a chance I'll stop in there and see what I can lean. At least the body make.
30ft Highway Trailer Co. Lowboy (A53473)
30ft Highway...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2 1/2 Ton Military Truck, 6x6, 16' Flatbed (A52384)
2 1/2 Ton Military...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
