3 PT Upper Housing Crack B7610
   / 3 PT Upper Housing Crack B7610 #1
cuda130103
I noted a small leak near the upper 3pt arms.(the hydraulic arms) Just a little fluid running down the housing.
It turns out it is from a hair line crack that goes from one bolt hole to the other bolt hole on the other side. This is that huge heavy cover that includes the 3 pt lifting ram. I am concerned with what caused this before I repair it. I think I can weld it. It is cast but, I don't think it is cast iron.
The tractor is new to me,so I don't know its history.
I pulled the housing off, not too difficult. You just have to disconnect all the linkages and remove the bolts.
What I found also was a broke piece of plate steel This piece is maybe 4 inches square by 1/4 thick and sits in a channel in the lower housing. I'm not sure what is for??? It just sits in there loose. It looks like it might be a stop for the 3pt Ram at its fully raised position.
I surmise once it breaks it could then move back farther and push against the housing and crack it?? But what broke it?? 3pt mis-adjusted?
Anyway.. Anybody else out there have a simliar problem or suggestions to for non-repetive damage?
   / 3 PT Upper Housing Crack B7610 #2
Does your tractor have a heavy duty top link bracket. Highly recommended for tractors that use heavy duty attachments. The bracket comes with a 3PH backhoe. But my dealer recommended one for my tractor because of a couple of the heavy attachments I have. I later purchased a BH. Here is a link to a thread on the B2910. Parts are simialar to your model tractor.
27-2910-toplink
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
CATERPILLAR 304E CR EXCAVATOR (A51242)
CATERPILLAR 304E...
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
1268 (A50490)
1268 (A50490)
2803 (A50460)
2803 (A50460)
