Spreader 3 Pt Spreader for Grass Seeding?
   / 3 Pt Spreader for Grass Seeding? #1
tarious
Bronze Member
Grand Forks, ND
JD 3320
Greetings,
Anyone have any advice for planting grass seed for a lawn? I am familiar with the prep work, but I just *hate* renting equipment. The local TSC store has a cosmos poly hopper 3 pt spreader that appears to be designed for fertilizer. Could it be used to plant grass?
I plan to spray the existing growth with glyphosate, wait a week, roto-till, then box blade to level, then landscape rake to pick up small rocks and debris...then I was considering using a broadcast seeder like I mentioned above and following it with a 900 pound lawn roller behind that.
The local rental place wants 200/day for their "brillo" or something like that...I'd rather spend 1000 and own something than pay 200 for rental...I think the TSC one was around $400.00.
Any advice would be appreciated.
   / 3 Pt Spreader for Grass Seeding? #2
</font><font color="blue" class="small">(
)</font>
Probably mean BRILLION. Finest landscape seeder made. You CAN broadcast seed. Not the most accurate method. Brillion seeder probably is the most accurate grass seeder.
   / 3 Pt Spreader for Grass Seeding? #3
How much area are you planting?
For normal sized lawns, I just use a drop seeder. It pushes easy and puts down an even spread. I wouldn't want to use it on an acre or more, but it's easy for smaller areas.
I've not used a 3PH spreader, but I can't see that spreading very evenly. For a large area, maybe it would do ok.
ron
I am seeding 5.5 acres. It has been mowed for years, but there is very little grass and rough terrain. Grass seed isn't cheap either, so I don't want to waste money using the 3 pt spreader, but if it is effective enough...I'll try it.
   / 3 Pt Spreader for Grass Seeding? #5
I have seeded several acres with a wrist mounted whirlybird fertilizer spreader. Very seldomyl did I need to shake it a bit to keep the seeds flowing. It's a lot of walking but like with any spreader you spread one way and then turn 90 and spread the other to prevent rows. I have had very good luck with this method. A 3ph spreader has the added advantage of an internal agitator or stirrer to keep the material flowing. Many are capable of spreading lime as well as fertilizer. Our sewage treatment plant produces a pelletized "solid waste based soil amendment" that is rated as a 4-4-4 organic fertilizer and the wrist whirly spread that too.
Get the spreader. It should fling grass just fine. Plus fertilizer and lime. If coverage isn't golf course quality don't worry it will fill in.
   / 3 Pt Spreader for Grass Seeding? #6
</font><font color="blue" class="small">( Many are capable of spreading lime as well as fertilizer. )</font> Do you mean pelletized lime or ag lime?
I have a 3 point and a shoulder bag spreader. Both have their uses--you can do a better job with less seed using the shoulder bag but I sure wouldn't want to spread fertilizer that way.
I don't think you'll regret getting a 3 point spreader--I haven't. Herd makes good ones, too.
   / 3 Pt Spreader for Grass Seeding? #7
Whadda ya mean, you wouldn't want to spread fertilizer with a shoulder bag? Last year I spread over 1000 pounds of lime and 300 of fertilizer along with 4 bu of oats, 2 bu of wheat, 2 bu of buckwheat, 100# of clover and 35# of brassica all with a shoulder bag. Oh, and I had to shlep the bags around to various staging area. Did about the same amounts the last 2 years, too.
Hmmm, come to think of it, that 3pt spreader does sound pretty good... What have I been thinking!
jb
   / 3 Pt Spreader for Grass Seeding? #8
That's how I got my wife to OK my first 3pt seeder purchase. I let her help me fertalize our 13 ac one year. About 2ac into it, she was telling me to go get the 3pt seeder..
Soundguy
   / 3 Pt Spreader for Grass Seeding? #9
"The local rental place wants 200/day for their "brillo" or something like that"
It would only take you a day.. and renting the grass seeding equipment would probably save you $200 in grass seed. Just plain old K31 went up $20 this year for a 50lb bag.
I have an old grain drill that has grass seed boxes on the rear.. you set the rate/per acre & off you go.
Take the time to make a good seed bed.. it'll pay off.
   / 3 Pt Spreader for Grass Seeding? #10
You have to use pelletized lime if using a broadcast spreader, otherwise you end up with a cloud of lime going everywhere instead of down on the ground (on equipment, cars, buildings, dogs, etc.), don't ask me how I know this /forums/images/graemlins/crazy.gif If using a drop spreader, the ag lime works just fine.
2006 Ford F-250 4x4 Reading Service Truck (A42742)
2006 Ford F-250...
2014 Fontaine Magnitude 55L PLU 60 Ton Tri-Axle RGN Lowboy Trailer With Stinger (A42742)
2014 Fontaine...
2008 ADVANCE ENGINEERED PRODUCTS PNEUMATIC TRAILER (A45333)
2008 ADVANCE...
2016 Ford Transit Connect XLT Cargo Van (A42742)
2016 Ford Transit...
2016 Ford Escape SUV (A42744)
2016 Ford Escape...
2006 WILSON TRAILER CO. WILSON TRAILER CO. (A45046)
2006 WILSON...
