grainger, northern tool, tractor supply, farm king, farm and fleet, any nearby tractor dealers, craiglist, ebay, amazon.
pending on needs, you might consider a 3pt hitch carry all, and then getting a skid /pallet sprayer. to toss on 3pt hitch carray all.
or instead of 3pt hitch carry all. see about some pallet forks. for a skid/pallet sprayer.
if you have a FEL (front end loader) and just need for "spot spraying" with a hand wand. toss a tank in bucket, and run the hose to wand back to tractor seat.
to note it. PTO version pumps vs 12v on demand pumps. the PTO pumps are always on, and can be a bit more costly. and PTO pumps are to me, better suited if you will be using the booms most of the time.
if you are just going to be "spot spraying" mostly. example fence lines, nuisance weeds / trees / bushes. the 12v on demand pumps have built in pressure switch. so they turn on/off as needed when ever you pull trigger on hand wand. or open valves to booms.
still favor a "pull behind" for like a riding lawn mower, or hook up to ATV. you can still pull them with a tractor or truck. making it a little bit more convenient for what ever you have going on. and a bit easier to un hook, and then scoot off to some spot in the garage. only issue is they can be a pain in rear to backup. and will like to jack knife on you quickly.
you do not need max size tank. consider 30 to 50 gallon tank size, and then re-fill as needed. (easier to store, more likely not use as much chemicals as needed, perhaps easier to clean)
smaller tanks = less sloshing of water/chemicals in tank. i have a lot of hills, so sloshing water = big *ughs* i do not want to tip over due to water sloshed to one side and was enough to cause an issue.
myself tend to need a "breather" and a washing even with a 30 gallon tank and single fill. always end up in a high wind spot. and it all ends up suddenly blowing back on me :/ not liking it one bit. even with me keeping boom nozzles right at ground level and turning the mist settings on nozzles back a good amount.
if you are looking for much bigger field sprayer, look at tractorhouse.com were you get up into 200 plus gallon tanks.
