3 pt sprayer for JD2305 ?
   / 3 pt sprayer for JD2305 ? #1
EasyE
North Carolina
JD 2305
Found a used sprayer, 50 gallon, 3pt, PTO driven. It has a hose that goes from the sprayer to the PTO and hooks up. My question is how does this work? This hose hooks to the PTO and generates pressure back to tank? Sorry but I have never used one! Help? /forums/images/graemlins/confused.gif
   / 3 pt sprayer for JD2305 ? #2
I have an upright 55 gallon sprayer. From your description (does this look like your unit? Sprayer) you may be missing the roller pump which has an inlet side and outflow side as shown in this link Roller pump . The pumps will go bad if not flushed and lubricated well after use. I have had great luck with my unit which is used to spray the lawn as well as a switchable tree sprayer. Good luck, let me know if you have other questions.
   / 3 pt sprayer for JD2305 ? #3
you need an inlet side hose from your tank and an outlet hose which would run to the spray boom or wand. Not sure what you have, maybe the pump is built into the tank??
   / 3 pt sprayer for JD2305 ? #4
One other concern I have. While I would love to have some sort of 3 pt sprayer like this on my 2210 for my yard ($$$) I myself would stick to less than 30 gallons for tank size because of the small stature of our machines. 50 gallons of liquid is going to weigh close to 500lbs plus the weight of the machine itself. My concern would be on uneven or hilly ground where as the tank begin to empty towards half you would have some 300 plus pound of liquid would begin sloshing around could flip you over? Wheel weights might be a nice precaution. Just a thought.
   / 3 pt sprayer for JD2305 ? #5
I just bought a 150 GAL 3pnt sprayer for my 4720. I have not tried it out yet, but it looks slick. 20' boom and a spray gun with a 25' hose. I will post pics when I have it all setup.
D.
2012 FORD F-650 (A50854)
2012 FORD F-650...
CATERPILLAR 304E CR EXCAVATOR (A51242)
CATERPILLAR 304E...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A51222)
2003 FONTAINE...
2017 Ford F-350 Ext. Cab Pickup Truck (A49461)
2017 Ford F-350...
GENERAC GP6500 GENERATOR (A50854)
GENERAC GP6500...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
