3 pt splitters(again)
   / 3 pt splitters(again) #1
Jeepnford
NE Missouri
Case DX35
I bought a Speeco 3 pt. splitter and want to make sure I have it all straight before use. The pressure side from the remote with the lever tied to that position goes to the inlet on the splitter valve. The outlet from the splitter goes to the other side of the remote. The splitter came with parts to change it to a closed center valve. Is that only used if you have a power beyond?
   / 3 pt splitters(again) #2
That is correct.
No, Power Beyond has NOTHING to do with it...Your system is Open Center because of the type of pump you have. You do not need those parts.
CFG Industrial SAII100 (A50123)
CFG Industrial...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
New Holland C345 (A50123)
New Holland C345...
2013 Morooka MST-2200vd Crawler Carrier (A52384)
2013 Morooka...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2017 John Deere 652R (A50123)
2017 John Deere...
