Rake 3 PT Power Rake
   / 3 PT Power Rake #1
Stormtruck2
Bronze Member
Mechanicsville, Iowa
02 JD 4600 FEL, 72 MM Mower, Cab
I'm trying to find, if they even exist, a PTO powered 3 PT power rake. All I can find are 22" walk behind blue bird type power rakes. I'm a notta gonna do a 3 acres atta way.:laughing: Any suggestions are welcome. I may just end up tilling the whole dang thing up and starting over if I don't find the power rake.:(
   / 3 PT Power Rake #2
Tractor Harley Rakes, Power Box Rakes, 3 Point Hitch, PTO
be sitting down when you look at the price.... Someone on the board built one...
   / 3 PT Power Rake #3
Call some rental companies that rent tractors. They may rent one, much cheaper than spending the money.
   / 3 PT Power Rake
The Harley rake isn't really what I was looking for. They are expensive though. What I was looking for has rotating vertical blades the slice the soil and pull up the thatch. The Harley rake looks like it just peels the turf right off. I have used Power Rakes before on my little lawns and they do a great job of pulling the thatch up. Lots of raking when your done. I would think that golf courses would use them to prevent thatch build up.
   / 3 PT Power Rake #5
This what you want?
Tractor 3 Point Hitch 60" Pine Straw Rake PSR-5', also dethatcher
   / 3 PT Power Rake #8
I was looking for the same thing before. The best option I found that people recommended was a rotary broom. The bristles are stiff enough that they will dethatch a lawn plus you can use it for Spring plowing cleanup to remove stones and gravel. Almost all of the used ones that I could find where hydraulic units for skid steers, and the price was more than I wanted to pay. I was mostly looking for spring cleanup though, I ended up getting a rubber sweeper attachment for my trimmer.
   / 3 PT Power Rake
The Bush Hog Verticutter is what I am looking for, never heard it called that before though. The overseeder is great too, does two jobs at the same time. But the prices, dddddaaaaaannnnnnnggggggg! I have 6 acres that I would be rejuvenating, but still, that's a pot load of money. Thanks guys for the leads and help.:thumbsup:
   / 3 PT Power Rake #10
What about core aerating and overseeding as a base for your rejuvenation?
YANMAR VIO17 MINI EXCAVATOR (A45333)
YANMAR VIO17 MINI...
Pallet of Irrigation Hoses (A44502)
Pallet of...
John Deere 3038E (A44501)
John Deere 3038E...
2008 Ford F550 Truck (A42203)
2008 Ford F550...
HONDA EB 3000C CONVERTER (A45333)
HONDA EB 3000C...
AGT MX15RX Mini Excavator (A44501)
AGT MX15RX Mini...
