3-Point Hitch 3 pt. log splitter
   / 3 pt. log splitter #1
crystallake
Bronze Member
Jonesboro, AR
MX5100HST
I've been wanting a 3 pt. log splitter to run on a MX5100 Kubota. Read almost all the threads here and know to expect it to be a little slow. My spec show pump capacoty 9.5 gpm with power steering 4.9. Am I wasting my time think this will work? I see much smaller tractors using them on Youtube but dont know anything about there hydraulics.
   / 3 pt. log splitter #2
I think most people who have gone down the route you are planning will advise to go the stand alone splitter route.
I found I put needless hours on my tractor and suffered with slow action and low output.
Buy a cheap engine (chinese) model and you will be much happier. When the engine finally lets go you and then drive it off the tractor hydraulics.
The stand alone unit will have a two stage pump to make each cycle much quicker.
Dave M7040
   / 3 pt. log splitter #3
Majority of people seem to prefer stand alones but I am very happy with my 3 point splitter. Three reasons - No maintenance, very little storage space and quiet enough I don't need ear protection while I'm using it.
I have only about 3 gpm available so I have a Powerhorse 13 ton unit. You could probably handle the 20 ton model. It may be a little slow, but it's a two way splitter so there is no wait for a return stroke. Actual throughput is equal to stand alone splitters, in my experience.
Each to his own.
   / 3 pt. log splitter #4
I prefer standalone splitters. No need to put hours on the tractor. I'm not that worried about hours, but they affect resale value. I don't want my tractor tied up splitting wood. Another advantage is I pay a guy to split most of my wood. I leave the wood splitter in the shed which is unlocked. He can come split wood whenever he wants. I wouldn't do that with a 3 point splitter.
   / 3 pt. log splitter #5
I have a L3240 with a TSC country line 3 point splitter, very satisfied with the operation and speed, run engine between 1000 and 1500 rpms. I had the dealer set up the hydraulics the same as a backhoe connection. My reason for this setup after splitting wood for 46 years is not having to maintain another engine nor another hydraulic system. Not worrying about the motor sitting around for months on end and not starting when I need it is eliminated. The additional engine hours does not concern me since this is probably the last tractor I'll ever buy.
   / 3 pt. log splitter #6
I love my 3 point splitter, but it's powered by a pump that slides on the pto, it's fast and extremely impressive!.
Would I go back to a stand alone? NO,
IF, "I" was worried about putting hrs on my tractor, I'd figure I made a poor choice in tractor buying and move it on down the road! Then buying one I wouldn't have to worry about!
To the OP, your tractor will do what you are wanting to do, it's just going to run the splitter sloooow...
SR
   / 3 pt. log splitter #7
I love my 3 point splitter, but it's powered by a pump that slides on the pto, it's fast and extremely impressive!. Would I go back to a stand alone? NO, IF, "I" was worried about putting hrs on my tractor, I'd figure I made a poor choice in tractor buying and move it on down the road! Then buying one I wouldn't have to worry about! To the OP, your tractor will do what you are wanting to do, it's just going to run the splitter sloooow... SR
But you have multiple tractors. Would you want a pto splitter if you only had one tractor? I wouldn't mind powering my splitter with my B7100, but I wouldn't want it on my primary tractor. 9.5 GPM is about the same as a store bought stand alone splitter. It won't be a speed demon, but not like a turtle either. My B7100 only has 14 hp at the pto, but that would turn a pretty decent pump.
   / 3 pt. log splitter #8
I've also been happy with the 3 point splitter for the last 20 yrs. Last tractor was a little slower than this one but being able to lower or raise it for large blocks is a plus and easy to move around or into the pile where you don't have to man handle the blocks much. Easy to store & no maintenance. I think they both have a place depends how much you wish to invest & what you expect from it.
   / 3 pt. log splitter #9
I'll be honest with you... IF that was the case, it wouldn't be the case for long. I'd buy an older/used tractor, they can be found quite cheep. $3,000.00 will get you a decent tractor with modern features...
The problem with this site is, everyone "thinks" they have to keep up and only buy new tractors and that they have to be a CUT. lol
For the same money or less, they could have bought a much tougher farm tractor...
SR
   / 3 pt. log splitter #10
I have a three point splitter. I had a stand alone splitter. The three point splitter is a little slower but so am I, lol, it doesn't seem to bog down on old elm logs either. I like that I can lower it or raise it to the task at hand. Lowered to the ground I can roll the big diameter logs onto the saddle keeping my bad back out of the equation. I can also set the height so that I don't have to bend down to operate. So what am I saying? It is what suits you that matters.
Good luck with your choice.
JLG 2646 ES LIFT (A50322)
JLG 2646 ES LIFT...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
2012 Jaguar XJ Sedan (A50324)
2012 Jaguar XJ...
2020 Bobcat T76 R-Series (A47384)
2020 Bobcat T76...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
