3 PT Implements: Universal?
   / 3 PT Implements: Universal? #1
yankee7
OK, another dumb question from a newbie: are all 3 point implements universal? That is, can I attach a New Holland baler to a Kubota or John Deere tractor, or are they "dedicated". Or can you interchange them with adaptors or kits?
Thanks!
Dave
   / 3 PT Implements: Universal? #2
Yes and No, the implements are universal within a size class (Class 0-3), or in other words the implement is designed for a certain size of tractor (ie:30-60 hp) and will fit any tractor of that size range. however once you get into "quickhitches", "iMatch" and the like, all bets are off.
a baler (generally) uses the PTO and the hitch, it does not use the 3point, however the PTO size is standardized, so you can use any brand of tractor with any baler.
HTH
Aaron Z
   / 3 PT Implements: Universal? #3
As said within a given class or category they're universal. One thing to check of course is the PTO shaft when moving from one tractor to another. Too long and you can damage your tractor as it 'jams' the PTO mechanism, too short and you risk the two halves popping apart in operation.
   / 3 PT Implements: Universal? #4
And that can lead to frequent underwear changes.:eek:
2006 Ford E-350 Super Duty Enclosed Service Van (A42742)
2006 Ford E-350...
3pt Hydraulic Broom Attachment (A42021)
3pt Hydraulic...
1020 (A44391)
1020 (A44391)
Scissor Lift (A44571)
10’ WROUGHT IRON SITE FENCE (A45046)
10’ WROUGHT IRON...
2017 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A42742)
2017 JCB 930...
