3 pt hitch
   / 3 pt hitch #1
kioti
Please can someone help me. 3 pt hitch will not go up and down. Have changed filter. Last year, I put up disc cutter, raised 3 pt, parked Kioti for winter. Got it out this year, went to lower 3 pt. Would not lower. Help Please.
   / 3 pt hitch
   / 3 pt hitch #3
Is the knob below the seat turned off? Is there any weight on the hitch?
   / 3 pt hitch #4
   / 3 pt hitch #5
Do you have a pic or pdf of the hyd section on that tractor? We need to see what sort of valving it uses so that we can offer up possible soloutions.. or even possible problem areas. Specifically.. we need to see how the exhaust valve is setup.. whether it is a unloading system.. etc..
Soundguy
   / 3 pt hitch #6
Soundguy
   / 3 pt hitch
Hi Soundguy,
I guess I got one of those problems out of the org like always, if something different is going to happen, it will happen to me. I thank you for your thoughts and time.
Just for your info, everything else works. Bucket, rear hly system, levers. I guess what I was asking was what to get prepared for and oh yes DK50. Thanks Again
wallace
   / 3 pt hitch
Hi Soundguy,
wallace
   / 3 pt hitch #9
I'd suspect some portion of the exhaust valve/unload valve..( if it were a ford /forums/images/graemlins/grin.gif ) hard to say on yours without seeing a schematic of your 3pt valve setup..
Soundguy
   / 3 pt hitch #10
Soundguy
1973 CATERPILLAR 988 LOADER (A52576)
1973 CATERPILLAR...
HYSTER H60XT FORKLIFT (A52472)
HYSTER H60XT...
New Long Forks (A53002)
New Long Forks...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
