3 pt. hitch will not hold in neutral position...
   / 3 pt. hitch will not hold in neutral position... #1
Hinomoto n239
North Carolina
Hinomoto N239
I have a Hinomoto N239 with an electric directional control valve (solenoids) that operates the 3 point hitch
The 3 point hitch goes up and down as I move the switch to up and down. In the neutral position it stops in place but slowly leaks down (it does not hold in place). Also, sometimes when the 3 pt. hitch is all the way down and I stand on it and flip the switch to up, it doesn't have the pull to get started...but once started up it goes with strength.
Does anyone know what the problem would be?
   / 3 pt. hitch will not hold in neutral position... #2
Sounds like the cylinder is scored or a valve is defective.
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
Ford Tractor (A50120)
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
GooseNeck Trailer (A52377)
GooseNeck Trailer...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
