3 Pt Hitch & Pins
   / 3 Pt Hitch & Pins #1
boustany
Platinum Member
Campbellville, Ontario
Kubota L3010, BX2200
Hello and thanks in advance for the help.
I recently bought my 3010 plus a backhoe and rear mount snowblower. I was surprised to discover the blower did not come with the 3pt hitch pins. Furthermore, the pins used on the backhoe are too short to install the blower.
No problem - I measured the requirements of the blower lower pins (being 3 3/8" of an inch long, needing 7/8" of spacers in between), and went off to an implement dealer, only to discover that pins seem to be available in 3 and 4" varieties. Plus spacers are available in 1 3/4" lengths.
Looking at the mechanics of the situation, I figure you don't want the implement (the blower in my case) to slosh back and forth much, suggesting a snug fit is desired for the 3 pt hitch and the yoke(s) on the blower. Similarly, having the pin too long (by about 7/8" in this case) doesn't stike me as being too good as it will lead to stress on the lynch pin.
So, should I administer a hacksaw and file to my pins, find another implement dealer (with different pins), or is this the way its supposed to be?
   / 3 Pt Hitch & Pins #2
Grab yourself a handfull of flat washers. I had the same problem with the top link on my blower, 2 washers on each side made a snug no slop connection.
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2012 John Deere 7280R MFWD Tractor (A52748)
2012 John Deere...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
