3 Pt hitch not working
   / 3 Pt hitch not working #1
Jmsmithy
Bronze Member
Russia, NY & Socialist Republic of NJ
2013 Kioti DK40SE HST
Hello All
HAPPY FOURTH OF JULY!!
I have a 2013 DK40SEHST and when I went to start and attach my brush hog yesterday my 3pt wouldn't move. It's been parked in my barn about a month since I last used it. I checked all fluids. Appears all connections etc as they should be as well....
Thoughts???
   / 3 Pt hitch not working #2
Not sure if you checked the easy bits first but: Is there a lever for your remotes and must it be in a different position that what you are in, (Can not recall which one is the right one on my DK but there is an "A" a "B" and a "Neutral" position. Also, if you have a loader on and it is bypassing, (lever hard over one way or another) it may be depriving the 3pth of flow. Lastly, I have a knob that controls flow rate, (just below front of seat), if you have one, ensure it is in correct position. If unsure, try mid-way and once running adjust accordingly. Good luck and please let us know what the problem is and the fix. Thanks
   / 3 Pt hitch not working #3
this is probably your problem.
Unscrew it until the 3pt drops on it's own. It might take a couple of turns.
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
Kubota BX22 TLB Compact Tractor (RUNS) (A50774)
Kubota BX22 TLB...
W&A 3pt Ditcher (A50121)
W&A 3pt Ditcher...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
