plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,394
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
Cleaning up my forestry mess, I will often be working alone. Mostly level ground, lots of brush and debris, many trees down, average log size 10", mostly pine, ranging up to very long lengths. I've never done this before. I will have a 50+ hp cab tractor with front grapple and rear landscape rake. I'm wanting to move the trees to a work area, then buck them into rounds and split for firewood. I envision using the grapple to pick up an end of a log, drag it to my work area, grab it again in the center to lift it completely off the ground, then saw it into rounds while off the ground.
I'm looking at a Wallenstein LX5100 3 pt grapple. Or a Wallenstein or Farmi skidding winch. It seems the 3 pt grapple, for a single operator, is more productive. That assumes mostly level terrain and a clear area to work in, and I have both. A grapple lets me back up. grab a tree, and go. The winch requires me to dismount the tractor, pull the cable out to the tree, hook up a choker, winch it in, remount the tractor, and go. But I not ever done either of these tasks so that's just my impressions, which might be wrong?
The winch is clearly superior if you cant back up to the tree or if you need to "thread the needle" through a forest. But for single person operation in an open area, is the grapple better? I am curious to hear from those with experience, as I see many "winch operators" but only very few that use a 3 pt grapple?
