3 pt driveshaft length
   / 3 pt driveshaft length #1
JimC
Seguin, TX
Kubota BX2200
I got me a (old) new shredder and need to shorten the 3 pt driveshaft, How much overlap should you have at the lower operating position so the shaft won't be too long in the raised position?
   / 3 pt driveshaft length #2
JimC, the short answer is to have a minimum of 6" overlap at the point of greatest extension and have the overlap 3" short of the u-joint at the point of least extension. However what I would suggest is that you go to Bush Hog and scroll down to page 9 and read the instructions complete with pictures.
   / 3 pt driveshaft length #3
With the Implement on the ground AND attached to the tractor(3pt or drawbar),The"Fullycollapsed/telescoped to its whole lenth " driveshaft should just clear the PTO splined power shaft on the tractor. It will extend only 2 -3 inches to fit and lockon the power shaft. The driveshaft gets longer and telescopes out when you lift the implement off the ground . You should leave plenty of innershaft to be safe
Thanks to both of you guys, The Bush Hog manual is real clear and the additional info on setting the length with the shaft in its collapsed positionand the implement raised makes it so clear and simple that I don't think I can mess it up in anyway.
Love this TBN wedsite.
JimC
   / 3 pt driveshaft length #5
Some specialty shafts allow 3" overlap. We typically see these shafts used in chipper applications but I have seen them used in some other applications.
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
Rogator New Leader RG1100 (A50123)
Rogator New Leader...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
