3-pt Counterweight vs. FEL Lift Capacity
   / 3-pt Counterweight vs. FEL Lift Capacity #1
knute_m
Moved from Hilltop Hollow, WV to Outskirts of Winc
Down to my lovable little red Mahindra with FEL, and backhoe.
This may seem like a silly question. But, I've got some rather long, heavy, and very awkward things I'd like to move with my FEL. Because they are in a loft in an old shed, they are about 6-7 feet off the ground. I know I'll need a lot of counter-balancing (I've got loaded rear tires) on the tractor. I've picked up and moved some that were already on the ground, and I believe they weigh close to the lifting/curling capacity of my FEL. I used my brush hog mower as my counterweight without any real issues.
Trying to grab them at their center of gravity is also not going to be easy due to their location, plus their height above ground, means I'm going to need several hundred more pounds of counterweight. I don't trust the roof, so a chain hoist isn't a good alternative.
Once I get them to the ground, I don't have a problem. I have an excavator. But I can't get the excavator, or it's arm, in the building.
So, if I have a heavy counterweight on my 3-point hitch that is not resting on the ground, does that weight reduce the hydraulic lift/hold capacity of my FEL? And vice versa, if I've got a near-capacity weight load in the FEL that is several inches off the ground, does it affect how much I can lift with the 3-pt hitch?
What I don't know is how the original owner got them where they are!
Thanks,
Knute
   / 3-pt Counterweight vs. FEL Lift Capacity #3
Any chance you can lower them one end at a time? That way the FEL is only lifting 1/2 the weight. The longer the object, the easier that should be. You would want to secure the end that remains elevated so it doesn't slip while you lower the other end. If the object is only 6-7 ft in length, obviously that wouldn't work.
   / 3-pt Counterweight vs. FEL Lift Capacity #4
I believe the lift capacities of FEL and 3ph are independent. Speed of movement likely is reduced if you try to do both at same time but Max lift will be same.
   / 3-pt Counterweight vs. FEL Lift Capacity #5
On my tractor the lift capacity of the FEL and 3-pt are independent. Dunno if that's true for your tractor? Do you have any owner's manual to answer that question and/or tell you the capacity of your FEL and 3-pt with ballast requirements? The main thing you want to be careful of is having your FEL up high on sloped ground since that can flip your tractor. Would using some 10 foot 2X10 lumber (or 4X4) as a ramp from the loft be feasible? That way you could slid the objects down and your FEL wouldn't need to support the whole weight.
   / 3-pt Counterweight vs. FEL Lift Capacity #6
You can load the 3 PH up with as much counterweight as the manufacturer allows for lift capacity and it wont affect the lift of the FEL, it WILL remove a substantial amount of weight from the front tires and make the lift more stable. Think of the tractor just like a crane, put on more counterweight on the back to increase lift capacity on the boom (FEL in this case) You could stack concrete blocks, or other heavy object, on the bush hog for even more weight to increase you safe lift capacity on the FEL.
   / 3-pt Counterweight vs. FEL Lift Capacity #7
The FEL & rear 3PL capacities are usually independent ratings, suggest though you check the overall capacity of your tractor first & critically also the rating of the tyres it may have fitted (the last thing you wish for in the middle of a heavy lift is a tyre letting go......).
Whilst loading up your brush hog as a counter weight might be an option be cautious not to overload the implement mounting points excessively, I've successfully used 4x water filled c.40gal plastic drums chained on their side on a brush hog as a counterweight only to find cracks in the implement mounting welds post the "lift"....in future if I'm running that close to the wind I'll use a truck mounted hyd crane.
   / 3-pt Counterweight vs. FEL Lift Capacity #8
I'd offer a slight clarification to what Gary said. I'm not sure how they are rating the lift capacity of a given FEL. You aren't going to increase the amount your cylinders will push up by any amount of ballast. But whatever they can lift, you'll do it much more safely. So I suppose that if the rating isn't necessarily as high as what the cylinders will push, yes, you'll increase the capacity by transferring weight off the front axle.
   / 3-pt Counterweight vs. FEL Lift Capacity #9
Just operate one function at a time - the FEL or the 3PH. Once the ballast is off of the ground it is locked in position and allows the full capacity of the pump to be used with the FEL.
You can test it out by lifting the loads that you already have on the ground. Try to lift the 3PH and use the loader at the same time to see the effect.
Not sure about the use of a Bush Hog as a ballast when working in a shed. You must be really good at tractor maneuvering. A small pallet loaded with weight of some sort (bags of sand, rocks, water containers, etc.) on a Carry All would let you get around a bit easier.
CountyLine® Carry All, Category 1 Quick Hitch Compatible - 2128210 | Tractor Supply Company
2006 Peterbilt 379 Wet Kit Tri-Axle Day Cab Truck Tractor (A51692)
2006 Peterbilt 379...
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
1840 (A51248)
1840 (A51248)
MAKITA TABLE SAW (A53843)
MAKITA TABLE SAW...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
