3 pt Ballast
   / 3 pt Ballast #1
trctrman
Bourbon, Mo
'05 MF1533 W/1525FEL & '50 8N
FYI - An easy way to add an extra 500 lbs or so. I chained a 55 gallon drum to my 3 pt carry all and filled it with water. My tires are also loaded, but the extra weight on the 3 pt did make a difference. Also, I mounted a garden hose adapter where the small bung was, attached hose with drum lifted, and I had enough water pressure from gravity to water a few remote trees/plants & what not - but make sure the drum is cleaned out good as not to kill what you're watering.
   / 3 pt Ballast #2
good idea - I just used some expanded steel mesh and a couple pieces of angle iron to make a bracket on my box blade and stack buckets full of concrete on it when i need the extra ballast. (can also use the buckets as tent weights for the "portable garage")
FRONTIER LP2196 LOT NUMBER 113 (A53084)
FRONTIER LP2196...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
66in Light Material Bucket Skid Steer Connection (A53472)
66in Light...
2015 KOMATSU PC35 MR-3 EXCAVATOR (A51246)
2015 KOMATSU PC35...
