3 point very weak barely lifts box blade
   / 3 point very weak barely lifts box blade #1
OutbackL130
chickamauga
L130, 420
I just finished installing a 3 point hitch on my 1984 john deere 420 and hooked it up to my 4' box blade which weighs around 300lbs. The tractor struggles to lift the box blade when empty and it wont lift at all loaded with gravel. The hydraulics feel very weak. How much weight should the tractor be able to lift with the 3 point hitch? I have heard people lifting 700lb ballast boxes so there is definately something wrong with my tractor.
Also, how many inches of lifting range should I have measured at the end of the lift arms? Mine does not move more than a few inches up and down.
   / 3 point very weak barely lifts box blade #2
Have you checked your pressure on the hydraulics? Don't know about your model but my x749 can lift my 420lb land plane with a 180 lb helper standing on it without issues.
   / 3 point very weak barely lifts box blade #3
I think those tractors are suppose to lift around 450 lbs by Deere but they actually lift more. In order to move the 3 pt to it min and max range you have to set the deck stop to all the way down.
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2000 Ford F-250 4X4 Service Body Truck (A55788)
2000 Ford F-250...
UNUSED RAYTREE RMH680 HYD HAMMER (A54757)
UNUSED RAYTREE...
2000 Ditch Witch 3700DD Ride-On Trencher (A55787)
2000 Ditch Witch...
