3 point scissor lift
   / 3 point scissor lift #1
RHughes
Autauga County, AL
New Holland TN65
I was looking through the new Valu Bilt catalog this weekend (yep, a dangerious thing to do) and saw an attachment called a scissor lift for a 3PH on page 315. According to the short description, this is to increase the lift height of the hitch to double stack round bails, etc.
For the life of me, I can't see how this thing attaches to the tractor and then to the implement. Has anyone here used one of these things? I'm certain I could find a use for this if it works as advertised.
Regards,
   / 3 point scissor lift #2
Fred Cain High Lift- $450 with HYD. Cyl
   / 3 point scissor lift #3
Ralph the high lifts like that take the place of the third arm. When you raise the lift arms the boom pivot raises the lift 3 times higher. THey workd good with a bale spear and a cylinder to til the spear down, some have paralell links that keep the load level the whole time. Most come with the spear but a few come to attach to any 3point tool. I have made a few like that one of my friends has one he puts his boom pole on, and he sw my 3 point looader and then put his scoop on it. I built one for my neighbors Jubilee and can ift the bootom of the bucket 66 inches, I built it and the bucket as a loader only but i have a frien with forks on his., I build mine mostly tripp buckets for older tractors.
Now the last few i built just mount like a 3 point hitch and have a hydraulic lift boom and bucket.
   / 3 point scissor lift #4
wish you where close, i'd sell you one.. haven't used it since i got a fel...but then i swore never to sell any attachments again, so maybe i'd just loan it to you..
heehaw
Now that I see a real picture and description, it seems obvious!
I guess I know what my next do-it-yourself project is going to be /forums/images/graemlins/grin.gif
   / 3 point scissor lift #6
watch autions etc..you can find these with out the hay spike and hyd cylinder for $100 or less..
heehaw
   / 3 point scissor lift #7
If it increases the lift height via mechanical advantage, surely there must be a decrease in load capacity?
   / 3 point scissor lift #8
You are correct Gary--If you are moving 1500 pound + rolls of hay? You will need a Minimum of 65 HP tractor (bigger is better). As it goes thru the scissor action, the weight is shifted to the rear about 14 additional inches, This does create a front end stability problem on smaller tractors and most lift systems will stall at that point on smaller tractors (under 50 HP)--With that said, a 40 HP tractor and 800 pound roll hay works just fine--We use this device on our farm to feed 1000 roll of hay annually--The hyd cyl is not really needed for stacking or loading. If you are going to slide off the roll into the hayring, while feeding, then you will need the cylender--Ken Sweet
Sweet Farm Equipment Co. "Hay Specialists*
   / 3 point scissor lift #9
That's what I figured Ken. Unless This piece of equipment operated under some new laws of physics!
Thanks for the confirmation.
   / 3 point scissor lift #10
heehaw
Hey heehaw, or anyone else, I am looking for the attachment you guys are talking about. I am looking to buy one but could only find one for $459 (that does include shipping). I can't find any on craigslist or ebay can you tell me where I might find one cheaper?
2016 Ford F-150 XL (A44501)
2016 Ford F-150 XL...
TBD FLAT BED (A45333)
VOLVO 12.1 L FRONT CLIP (INOPERABLE) (A45046)
VOLVO 12.1 L FRONT...
2012 WESTERN STAR 4900 (A45046)
2012 WESTERN STAR...
2010 DODGE RAM 2500 (A45046)
2010 DODGE RAM...
2016 Ford Explorer AWD SUV (A44572)
2016 Ford Explorer...
