3-point problem
   / 3-point problem #1
Django
While rototilling some rough ground the three point went out and was unable to lift the tiller. I have a Satoh Stallion (1980) and the loader works fine. Any ideas on how to fix this? Thanks.
   / 3-point problem #2
Sounds like the internal relief let go or is stuck open. /forums/images/graemlins/confused.gif
If you remove all attachments will it try and move?
   / 3-point problem #3
Or an O ring on the piston tore. If the loader is working fine and it is driven by the same pump then I would not think relief valve.
However is the lift has its own pump then all bets are off.
   / 3-point problem #4
Sounds like a piece of contamination or metal fragment may have gotten into the lift arm valve. If you have a filter for your 3 pt. hitch like mine does; you might try cleaning it out and try it again. Otherwise you may have to do some surgery ton the pt. lift. /forums/images/graemlins/confused.gif
   / 3-point problem #5
If the TPH acts dead, I would start at the TPH control lever and work my way to the TPH housing, moving the lever and making sure all the attached linkages are moving to. One might of come loose. Also would check for a shut off/bypass handle below the seat, may have vibrated to hold/bypass position if it has one.
If its attempting to lift but doesn't, I would do like the others recommended.
   / 3-point problem #6
Some of those machines do have a seperate pump for the 3ph as well as a seperate clutch/engaging lever.
UNUSED GREAT BEAR 1.5CY SELF DUMPING HOPPER (A51248)
UNUSED GREAT BEAR...
2004 CATERPILLAR 262B SKID STEER (A51246)
2004 CATERPILLAR...
MAH QUICK ATTACH MAST W/ 48" FORKS (A51246)
MAH QUICK ATTACH...
2023 WESSEX RMX500 LOT IDENTIFIER 90 (A53084)
2023 WESSEX RMX500...
2025 CFG Industrial QK18R (A50123)
2025 CFG...
UNUSED RAYTREE RMBD72-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
