3 Point Post Augers
   / 3 Point Post Augers #1
bobbart
Kubota BX2200
I have been using 6" Post Augers from Tractor Supply. I have had to replace the first one because after a few holes the teeth and spiral tip wore down to nothing.
Now dont get me wrong and think that I just tried to drill into concrete. I have found that I have really thick hard clay under about the first foot. Of course there is small rocks like no bigger than a golf ball. Not a lot but enough to grind it down without knowing it is because I do not see the rocks often. But since the clay is so dense I have to sit and let it scrape and scrape.
So after the first fail, I picked up another to start again. The teeth wore down pretty fast in my eyes. I went to replace them and the nut had word down so we had to torch it off. I replaced the teeth and bolts and started again. Well in total I have done around 1 hundred holes and were now looking at new teeth and possible a new spiral tip.
Is there anything out there that would hold up better?
   / 3 Point Post Augers #2
I used a rental a few times and one auger had replaceable "teeth" and another was hard faced welded up.
   / 3 Point Post Augers #3
Might want to call Everything attachments, and Titan Attachments to get their input on some options for you. Maybe even AgriSupply, although I'm not sure about their quality. Might be good, I just don't know.
   / 3 Point Post Augers #5
Danuser model F-8 and don"t look back.5 year gear box warranty.
   / 3 Point Post Augers #6
I also bought a cheapo auger, it pretty much was a POS! I then bought a Bush Hog brand auger, and it's been a very good auger, that's holding up well...
That was a while ago, so I don't know if the current BH augers are still good or not.
SR
   / 3 Point Post Augers #7
I bought a really cheap used phd with a 9" and 12" augers a long while ago. It looked like ****, but was in good shape and cleaned up nice. It turned out to be a Speeco brand.
The teeth on both augers were shot. The center points were good. I could not find hardened replacement teeth for either auger, so I made my own out of hot rolled steel stock. The ground was semi hard and rocky. These teeth cut surprisingly well in all the soils I used it with. The teeth didn't last long but were cheap and easy to replace often. For the times and way I used that digger, it worked out well and was very economical.
   / 3 Point Post Augers #8
If you want something heavy duty go with an auger designed for a skid steer mounted auger they are WAY heavier duty with better and more options for replacement parts. I've had both 3 point and skid steer mounted hydro augers and there is no comparison in build quality and material thickness between the two.
   / 3 Point Post Augers #9
Same thing happened to me. I just bought a new point and teeth. I then hardfaced them and the edge of the flighting.
They are still going.
   / 3 Point Post Augers #10
I have a place near Rocky Creek - so named for good reason. A few years ago, I started looking for a PTO auger that could handle very rocky ground (pounding a T post or piece of rebar into the ground here usually requires at least three tries, moving a bit each time). I found they existed, but started at 5 or 6 thousand dollars. I can’t help wondering if anyone has come up with a hard rock tip for the average auger, maybe a tapered hard point that acts as a pilot. I am not about to buy a $6,000 auger for my $2,500 Massey Ferguson, just to fence 1.5 acres.
Our other place is rocky but not as rocky as here, so a standard auger might work OK on that 19 acres.
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2017 Freightliner M2 106 24FT Box Truck (A50323)
2017 Freightliner...
John Deere HPX Gator (A50514)
John Deere HPX...
International 5488 2wd Tractor (A52128)
International 5488...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52128)
Toyota 6FGU25...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
