3 point not working, lever snapped off? Cause?
   / 3 point not working, lever snapped off? Cause? #1
znowybird
I bought a couple Kubota L245h from a dealer down in kentucky. I couldn't go down and look at them so i took him on his word. Needless to say everyone i bought but this one is in good condition.
The 3 point lift arm lever is snapped off on this machine and before i got to far into it I wanted to hear some ideas. I assume something has to be pretty seized up inside for you to break that lift arm lever.
So i dismantled enough to be able to get at the control lever and try and turn it with no luck in turning it. I noticed that the position control lever which is on the same rod seems to move freely.
As I have not had any problems with 3 pt lifts before I wanted to err on the side of caution. I took the bolts off the top and everything that I can see that could possibly attach it to the rear end but could not for the life of me get it to pop off. I wasn't sure if I have to remove a cylinder or some sort of linkage before I popped the top off or what?
I guess I'm asking what are the likely causes of such problems? And if the lid is just extremely stubborn or needs some other work to remove.
Thanks,
Adam
I have a copy of the parts breakdown if someone needs to take a look at it, but i'd imagine they are all pretty similar.
   / 3 point not working, lever snapped off? Cause? #2
Some pics would help along with your explanation. Maybe pics and a shot of the parts breakdown posted.
Well here is the parts diagram.
  • Kubota-L245H-HYDRAULIC SYSTEM.pdf
   / 3 point not working, lever snapped off? Cause? #4
Good
Now which part snapped off? number from parts list?
page 4, item 25, the lever assembly is snapped off at the bottom. I assume something had to be wrong if someone put enough force on a lever to snap it like that. And when i try and get the assembly to rotate i can't, don't want to force it anymore, on the other tractors is moves nice and easy.
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
