Backhoe 3 point Long 1199A on Case 1030
   / 3 point Long 1199A on Case 1030 #1
havlo65
Mishicot Wis
Case 1490 1470 2390 DC 1030 IH SW6 W6 David Brown 990 Case 446 Deutz Allis 1920
I want to attach a LONG 1199a 3 point backhoe to my 1030 Case tractor.The tractor has a front end loader. The backhoe runs off the tractor hydraulics.The loader is using all my 4 remotes on the back of the tractor.I don't know how to connect the backhoe to the tractor remotes with the loader using all my remotes now.Was also wondering if I would have to tie one of the levers on the tractor back when using the backhoe.I also own a Case 1490 with 4 remotes and a joystick and a Case 2390 with 4 remotes. Would either of these be a better choice for attaching the backhoe to? I just bought this backhoe last week and have'nt used it on any of these tractors yet.I would like to put it on the 1030 because it has the front loader on.If anybody has any ideas please reply. Thanks!!:)
   / 3 point Long 1199A on Case 1030 #2
Can't help you much, but just for clarity, I'll ask. My dad's 730 and 930 both had 2 remotes, which would be 4 hoses total. Does the 1030 really have 4 remotes? And if it does, why would a FEL need all 4 unless you had a grapple? What do the other tractors have again? They are a bit newer and larger and may have 4, I just don't know.
Hi
You are correct.The 1030 has 2 remotes and so do the other 2 tractors.I guess I thought 4 hoses was 4 remotes (my mistake) Thanks for reply,that should help get the right answers.:)
   / 3 point Long 1199A on Case 1030 #4
Does the 1030 have the hydraulic pump flow capacity (gallons per minute) to operate the backhoe?
I looked at the operators manual for the 1030 Case and it states that the GPM is 12.The operators manual for the Long 1199A backhoe states its max flow is 10 GPM.The tractor should be ok to run the backhoe.
KJ 10' Galvalume Corrugated Steel Panals (A50121)
KJ 10' Galvalume...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
1000 gal Fuel Tank (A50514)
1000 gal Fuel Tank...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
