3 point lift
   / 3 point lift #1
papachaz
Cedartown GA
LS XG 3025 shuttle w/LL 3110 FEL
on my XG3025, the 3 pt lift doesn't start up until I get the lever about half way up. I asked the mechanic at the dealer about it, and he said that's typical for new tractors the way they're plumbed it takes longer for the pump to get the oil back there.....which of course I'm not buying that. I've already decided that guy won't ever work on my tractor, but I digress....
so, how's your 3 pt lift, I'm used to my old Ford starting up as soon as I started the lever moving, and the pump on that thing was awful....
   / 3 point lift #2
I have to play with knob under the seat that is pto control
   / 3 point lift #3
The valve should control the speed of "drop" of the 3 point. My 3 point lift begins as soon as the lever is moved, even just a little. It will come up at the same speed regardless of the valve position(fast or slow)
   / 3 point lift #4
That valve will also lock out the 3 point completely
   / 3 point lift
yeah this valve doesn't stay where I put it either, it seems to unscrew all by itself. I'm doing my 50 hour service Monday, I'm going to see if I can figure something out. I know this valve controls the speed it drops, but it isn't supposed to effect the 'lift' right?
   / 3 point lift #6
My 3-point position control lever is all the way forward - my rear blade sits firmly planted on the ground - the 3-point lower arms will begin to lift when the position control lever is about 1/6 of the way towards being full back. In other words - when I have pulled the lever back about an inch.
The valve beside my seat controls the speed of rise or fall of the 3-point lower arms. It has NOTHING to do with "when" the 3-point arms will respond to the position control lever. It ONLY controls the speed.
   / 3 point lift
yep, got my book out and read through that section. nothing to do with when it starts to raise, even with the really poor translation from Korean to English ;)
   / 3 point lift #8
That's how my 3PL works. About half way 'forward' to lift.
It is very precise when lowering and maintaining the desired position, though. It's never bothered me in the 5 years I've had my 4105.
   / 3 point lift #9
I haven't had anything on the rear enough to be able to comment. The MMM acts about as you're describing though. Movement upwards is delayed after pulling the lever back.
   / 3 point lift #10
Do you have an attachment on when you are trying this? If you have no attachment on the lift arms, and they are lowered all the way, they should move instantaneously when you move the lever. If you have an attachment on that holds the arms up a little, the valve won't move until it gets to the position where the arms are.
2022 CATERPILLAR 249D3 SKID STEER (A51242)
2022 CATERPILLAR...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51242)
2005 KOMATSU...
Zimmerman 6 Lug Running Gear (A50774)
Zimmerman 6 Lug...
Steam Cleaner Tank (A50322)
Steam Cleaner Tank...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
