3 point lift stuck in up position
   / 3 point lift stuck in up position #1
ro55
al
kioti lk2552 ford 2000
I just changed the transmission hydraulic fluid in my kioti lk2552 and now the lift is stuck in the up position.Cleaned the filter and the speed drop control is not in the lock position.Do i need to bleed or is there something else not right.Replaced with correct fluid and amount.Any help would be appreciated.....
   / 3 point lift stuck in up position #2
sounds like a unload valve stuck i had that happen to me on a 5000 ford tractor a few years ago i dont know if this will help or not i hope so
   / 3 point lift stuck in up position #3
Did you adjust the rate of drop all the way out ? If it was working before you changed the fluid I can't see what you could have done to create this problem.
Is the hydraulic pump self priming? if not you may want to crack a line and see want happens.
There are some very sharp members on this subject, and I'm sure someone will be able to assist you, by the way welcome to the site.
duke
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
Online Buyers Premium (A47477)
Online Buyers...
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
