3-Point Hitch 3 point lift problem
   / 3 point lift problem #1
Gurney1010
Pikeville, TN
John Deere 5400
I have a John Deere 5400, dual remotes with a 520 loader. I bought the tractor basically as a "fire sale" deal as it was. Everything in the hydraulic system works fine with the exception of the 3 point lift arms. When I picked the tractor up, the lift arms were locked in the up position with the drop rate valve, which was closed. I opened the valve and the arms dropped, but they will not lift again. I know there is no problem with the pump because everything else works, and I don't think the problem is in the lift cylinder for the 3 pt. arms, because they were locked in the up position. I removed the drop rate valve, checked it out, and reinstalled it to no effect. I know there is the pressure releif valve, but I don't think there is most likely a problem with it since the loader works fine. Has anyone else had a problem along this line, and if so, can you give me any advice, or at least get me headed in the right direction? Thanks,
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
Land Honor Quick Attach Big Arm Backhoe (A50515)
Land Honor Quick...
UNUSED AGT SAWMILL (A51244)
UNUSED AGT SAWMILL...
ATLAS 10 1/2' DISC HARROW (A51243)
ATLAS 10 1/2' DISC...
2007 JARRAFF 540 TREE TRIMMER (A51242)
2007 JARRAFF 540...
SCAN FOR HAULING AND FINANCING INFORMATION (A51243)
SCAN FOR HAULING...
