3 point hydraulic drifting on ex2900
   / 3 point hydraulic drifting on ex2900 #1
alltherage
Western NY
2011 Cub Yanmar EX2900. 1939 Farmall A, 1940 Farmall H, 1959 Oliver 770
I have a finish mower on the back right now and I've noticed that every minute or 2 the hydraulics kick on and raise it. It's drifting down. This is during idle and I've never had this problem before. If I shut the tractor down I can hear the mower creak as it slowlyyyy sinks. The last 2 years I've been using a rather large snowblower in wintertime but it weighs less than the 3 point is rated for. 100 to 200 pounds less. I only use it on my driveway and it's not very often. Is there an adjustment or have i ruined a seal or something? This is a 2011 with 180 hours on it. The hydraulics have been used very little, just finish mower in the summer and blower in the winter. sporadic loader work but essentially this tractor has been babied. thanks for any help
   / 3 point hydraulic drifting on ex2900 #2
I wonder if the load check is leaking by.
the blower is 869 and the mower is 610. the 3 point is rated for 1100. here are some things i noticed...it only seems to do it if the lift arms are well over center or all the way up. it doesn't seem to do it if the lift arms are a bit over center or below. Also, it doesn't matter if i raise the rpms or if i'm at idle. I also checked to verify with a measuring device that it was actually sinking, and it was. It's doing it every 40 seconds or so. Like I said, if the arms are raised up only a little bit, so the mower is off the ground completely, it doesn't do it from what i've seen. ideas? and thanks so far
   / 3 point hydraulic drifting on ex2900 #5
Does it drift down with no load on it? My first guess would be the seal on the load check. Maybe someone else will chime in with a suggestion.
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
KSI Conveyor (A52748)
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
