3-point hitch
   / 3-point hitch #1
Sambo
Montana
John Deere 1050
I have two questions that I could use some help on.
First, I have a John Deere 1050 that has a backhoe and FEL. Recently I took the backhoe off, for the first time, to put on a brush hog. The problem is that I cannot get the 3-point hitch to raise or lower. I have looked through the manual and I think I am doing everything correct. Hoses from the backhoe, when it was removed, have been connected together. Hydraulic stop valve is open. I have tried raising the hitch with the draft sensing lever in "Position Control" and "Draft Control". I have adjusted the "speed of drop lever". The FEL works fine and the backhoe worked fine.
Second question. How much weight could my FEL lift. I don't have any paper work on it and have looked through the tractor manual and can't find anything. I am looking at getting some large precast retaining wall blocks that would be set using my tractor.
Any help would be appreciated. Thanks. I am definetly a tractor rookie so go easy on me.
   / 3-point hitch #2
Do you have a diverter block that needs to be changed back to allow 3pt to work?
Soundguy
   / 3-point hitch
Hey Soundguy,
I'm not sure about a diverter box. I think I know what your talking about. The diverter box would be where the hoses come into and the speed of drop lever is??? I have checked the tractor high and low for any levers I may be missing and haven't found anything. I will try again over the weekend.
On a side note I also posted this same question under the "John Deere" forum on this website. Not sure how it all works so I posted the question in two different topic areas. I got three replies in the "John Deere" Thread so I will probably follow that one. If you have time come take a look. Thanks Soundguy.
   / 3-point hitch
Hey Soundguy,
I'm not sure about a diverter box. I think I know what your talking about. The diverter box would be where the hoses come into and the speed of drop lever is??? I have checked the tractor high and low for any levers I may be missing and haven't found anything that does the trick. I will try again over the weekend.
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
2014 Wabash Tanker Trailer (TITLE) (A50774)
2014 Wabash Tanker...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 Ram 1500 4x4...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
