3 Point Hitch
   / 3 Point Hitch #1
froggy
Veteran Member
Cooke County, Texas
JD4320 with TNT, electric diverter, cruise control and air suspension seat.
More tidbits from the web:
3 Point Hitch
Category 0
For Tractors up to 17 Horsepower
Top Link Pins are 5/8 inch in Diameter
Lift Arm Pins are 5/8 inch in Diameter
Category 1
For Tractors with 18 to 45 Horsepower
Top Link Pins are 3/4 inch in Diameter
Lift Arm Pins are 7/8 inch in Diameter
Category 2
For Tractors with 46-95 Horsepower
Top Link Pins are 1 inch in Diameter
Lift Arm Pins are 1 and 1/8 inch in Diameter
Category 3
For Tractors with 95 Horsepower and Up
Top Link Pins are 1 and 1/4 inch in Diameter
Lift Arm Pins are 1 and 7/16 inch in Diameter
The Category I three -point hitch is based on three mounting points for the implement. The lift arms are the 2 steel or cast arms that extend rearward and provide the lift and are the pull-point for the implement. The top link is the third mounting point and extends from a top middle position out the rear of the tractor. Comparatively very little rearward force is applied from the top link unless the implement becomes bound up or twisted in some way. The standards require that the pin sizes on the implement and corresponding lift-arm holes be 7/8" (.88-.89). The top link uses a 3/4" (.76-.77) pin and hole. The distance from the tail of the PTO shaft to the lift arm ends is approximately 14 inches. The minimum spread between the lower lift arms will be about 26-27 inches, the maximum spread is normally out to 33 inches or more.
   / 3 Point Hitch #2
What is the maximum spread for the CAT 1 arms on the Kubota BX then? I thought they were less than 24".
Nice to have the specs however.
   / 3 Point Hitch #4
</font><font color="blue" class="small">( What is the maximum spread for the CAT 1 arms on the Kubota BX then? I thought they were less than 24". )</font>
Not every implement manufacturer follows the specs. The Cat 1 spec for spread is 26", yet I have a snowblower where the spread is 22".
There is no max or min specification. Just a nominal spec.
   / 3 Point Hitch
I knew about the TractorSmart site, but not SpeeCo.
   / 3 Point Hitch #7
There's a cat 0 "limited " or something of the sort also. I think it's design allows hookup to some cat 1 implements also.
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
2015 DODGE RAM...
2012 Hyundai Genesis Sedan (A51694)
2012 Hyundai...
Craftsman 917.257632 42in Riding Mower (A51694)
Craftsman...
2004 Lull 944E-42 Telehandler (A53117)
2004 Lull 944E-42...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
