3-point hitch
   / 3-point hitch #1
Smitty@Jamul
Jinma 2240
I have a Jinma 2240 Workhorse with a TY295 Diesel engine built in 1998. I'm having hydraulic issues with the 3-point hitch. I can raise and lower it but when i put a load on it won't lift. There is plenty of fluid. I keep reading about a knob with a set screw under the seat but can only find the fill port. Any suggestions?
   / 3-point hitch #2
You might get better response with this in the Chinese tractors section down in Other Brands. I don't know Jinmas but will try to answer generically.
The knob that is often under the seat is the bleed down valve. It controls the rate at which the 3pt hitch lowers when the lever to raise or lower the 3pt is set so the hitch goes down. It won't affect the hitch staying up when a load is on it and you're not operating the lift control.
It sounds like your lift cylinder seals may be shot. Or if you have position or draft control for the 3pt, that may be malfunctioning.
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2015 FREIGHTLINER...
2016 Chevrolet Impala Limited (A50120)
2016 Chevrolet...
2000 B&R 28' Gooseneck Trailer (A50121)
2000 B&R 28'...
Hyster H225E (A47384)
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A51572)
1999 Volvo VN...
