3 point hitch
   / 3 point hitch #1
Robert Sobczak
Mena, Ar
Max 22HST
the 3 point hitch lever on my mahindra 22 HST tractor
became very hard to operate in up or down position.
Previously it worked easy in both directions. Need to know
what and how to fix it.
   / 3 point hitch #2
:welcome:
I'm going to move your thread over to the Mahindra section to see if we can find you an answer.
   / 3 point hitch #3
Welcome to TBN........
On my 2615HST i accidentally sat on the 3 pt. handle and bent it. The handle worked very hard until I figured out the handle was bent. Not sure if that's the same problem you are having but worth checking. I also had problems with the diff lock pedal froze up. I found out I had to use generous amounts of penetrating oil on all linkages a couple times a year.
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
Toro Workman Utility Cart (A51694)
Toro Workman...
20" Sea Container (A47384)
20" Sea Container...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2008 ELGIN SWEEPER (A52472)
2008 ELGIN SWEEPER...
