3 point hitch
   / 3 point hitch #1
harleyc
lockport illinois
yanmar1720d
I removed my koyker loader for cylinder repairs and now 3 point dosen't work. is the hydraulic system a single pipe and removing loader is not letting flow to hitch?
   / 3 point hitch #2
Did you reconnect the hyd line in a series connection.
Before you had a loader, the flow was pump to 3pt.
With loader installed, you have pump, FEL, and 3pt.
So, connect the pump to the 3pt.
   / 3 point hitch
I bought tractor with loader and never had it off.don't have a manual and went from a 1946 case VAC to 1720 yanmar. the case was a very simple piece of equipment.Yanmar is learn as i go as most print is in /////// not english
   / 3 point hitch #4
If you remove the loader, connect the pump out line to the line from the 3pt.
2008 CHEVROLET C7500 SERVICE TRUCK (A51406)
2008 CHEVROLET...
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
NEW HOLLAND C362 SKID STEER (A52705)
NEW HOLLAND C362...
