3 point hitch won't lower 225e
   / 3 point hitch won't lower 225e #1
Drewintoledo
Bronze Member
Ohio
LS MT225HE
Tried truning the knob one way then the other. Inspected to make certain the shaft is not slipping. It's not.
3 point will not lower.
Any suggestions here?
   / 3 point hitch won't lower 225e #2
A few ideas:
If hyd hoses were removed from another implement (like a backhoe) in order to mount something to the 3-point, make sure hyd hoses are reconnected together properly at the back of the tractor.
Make sure hitch down speed valve knob is turned all the way to the Fast position.
Make sure hitch lowering handle is able to bottom out, i.e. the down limit knob isn’t set to keep it raised to a certain operating height.
If it still won’t lower try removing the PTO shaft where it connects to the tractor. If it lowers then the shaft is too long and it’s binding, preventing the hitch from lowering.
Hope this helps.
Excellent. I did remove my backhoe last night.
I just disconnected and re-connected the return hose and it's now working again.
Thank you sir!!
2007 CAT 904B (A47384)
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52128)
2004 Capacity Yard...
2009 MACK ELITE MRU613 GARBAGE TRUCK (A51243)
2009 MACK ELITE...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
