3-Point Hitch 3 point hitch valve questions
/ 3 point hitch valve questions #1
Dadsgreenpsd
Bronze Member
Maine
Jinma 254, and JCB 1550B
Greetings again!
I was getting ready to order a new valve for the jm 254, and decided to take it apart to see how it worked. Problem originally: binding, to the point where it would not work unless I clamped the vise-grips on the handle to keep it from rounding out the shaft.
So, I took it apart, only to find that all one piece of the internals were perfect, and moved very easily. I coated the spool (very lightly) with neversieze, and the actuator at the rear of the valve with neversieze..... took it out, and it worked perfectly, needing only light finger pressure to operate, etc... I worked for about an hour before I realized I had forgotten to tighten the 3 mounting bolts, and then I got a hydraulic bath.
so, this morning, I go out, and find that the valve is bound up again. even before starting the tractor. take it apart again, and it works perfectly again.... whats up with that? I would order a new valve, but I am afraid of the same thing happening. I guess I should have coated the spool with grease instead of neversieze, or am I wrong there? What is the recommended lube?
Any and all suggestions welcome.
Thanks!
I figger'd it out... :) I tightened the bottom bolts to about 40 ft/lbs, and if I tighten the top bolt to the same, it binds internally. If I leave the top bolt at around 20 ft/lbs, it works fine. I may use some loctite to ensure that the bolts stay put, and dont back out.
Hope this helps someone! :):)
2019 Chevrolet Cruz Sedan (A60352)
2019 Chevrolet...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
2016 Ford F-150 Ext. Cab Pickup Truck (A61568)
2016 Ford F-150...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A62129)
2020 CATERPILLAR...
2016 Ford Explorer 4WD SUV (A61569)
2016 Ford Explorer...
