3 Point Hitch slow
/ 3 Point Hitch slow #1
Yokurto
JD 2010 high crop
seems to be a common issue but in searching other posts i don't see many solutions that fixed the problem. my problem has a little twist, i don't think it is the "clogged pickup" or a bad pump. This is a Ford 445d 3 point with 4 remote valves for the gannon. the lift and the valves all work very slowly going up (they go fast down) unless the draft control lever is moved into the "fast" position (which is all the way up). when draft lever is all the way up then the lift moves rather quickly and the 4 remote valves all move faster up and the same down. that makes me think that there is nothing wrong with the pump and i removed the pickup piping and cleaned everything out so i know that is not an issue. also the manual F---S knob on the control valve seems to make no change when it is moved stop to stop while the valves or 3 point is moving. Has anyone got any dealt with this issue before?? i have the manual but it pretty much just says if slow it is clogged intake or pump and sense i can make it go fast when draft is all he way up i just dont think that is the issue
thanks
2013 Ford F-250 Ext. Cab Pickup Truck (A61568)
2013 Ford F-250...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
UNUSED KUBOTA 96" PIN ON BUCKET (A62130)
UNUSED KUBOTA 96"...
2008 CATERPILLAR 304C CR EXCAVATOR (A62129)
2008 CATERPILLAR...
2020 John Deere 6105E (A62180)
2020 John Deere...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
