3-Point Hitch 3 point hitch quesiton
   / 3 point hitch quesiton #1
shadled
South Central, PA
TC33DA w/14LA
This may sound like a really dumb question, but here goes. I just picked up my new TC33da w/fel, I added a Woods 60" back blade. The question is, Does the 3 point hookup provide down preasure? When I was using the blade it appeared to be in a float type mode. And I didnt have the lever in the "Float Position". Any suggestions.. /forums/images/graemlins/confused.gif
Shadled
   / 3 point hitch quesiton #2
No down pressure on these smaller tractors. Strictly gravity...
You can add weights to the blade to make it a bit more aggressive. That will work until you run out of traction.
   / 3 point hitch quesiton #3
Shadled,
The 3 PH does not have any down pressure. All the way down does actually float the implement, the float setting on the handle (at least my TC24D) is for the mid mount mower with a cushion mounting system. The only way to get a back blade to bite in better is add weight or change the angle by lengthening the top link to give a more aggressive bite.
Hope this helps.
Brad
Thanks guys for the quick reply.. That was one question I didnt ask the dealer. This is a great site I have learned a lot. /forums/images/graemlins/smile.gif
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2019 CATERPILLAR...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
Dingo TX427 Mini Skidloader (PARTS) (A50774)
Dingo TX427 Mini...
2016 Wilson Hopper Bottom Trailer (A50514)
2016 Wilson Hopper...
KMC 3360 4-row Basket Dump Peanut Combine (A52128)
KMC 3360 4-row...
1997 Wells Cargo Enclosed S/A Trailer (A50324)
1997 Wells Cargo...
