3 point hitch pins
   / 3 point hitch pins #1
kacole
Bronze Member
gaffney, sc
kubota mx5100
I'm fixing to cast myself a concrete ballast box (around 1500lbs) for my Kubota MX5100, I was planning on using an 1 1/8 round stock to connect to the 3pt hitch. Will the 1 1/8" round stock hold the weight without bending over time? Are the 3pt hitch pins hardened? I can use the Pins if I need to but I just have this round stock laying around and it would be simple to use?
   / 3 point hitch pins #2
As long as the round stock is supported close to the ends you should be fine. The hitch pins are hardened but the wear from carrying a ballast box would not be a problem. Pulling a disc with out hardened pins would put a lot of wear on them as they are always rubbing under stress..
thanks for the help round stock it is.
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
1996 Fiat Allis FG 65C Motorgrader (A51573)
1996 Fiat Allis FG...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2016 CANYCOM SC75 STAND ON DUMP BUGGY (A51246)
2016 CANYCOM SC75...
2003 Chevrolet Express Van, VIN # 1GCFG29T831102997 (A51572)
2003 Chevrolet...
JOHN DEERE TX LOT NUMBER 152 (A53084)
JOHN DEERE TX LOT...
