Hi all,
Still fairly new to tractors and enjoying getting to know my "new" 1984 B7100 HST-E. This forum has been a great help.
Now that mowing season is over, I am beginning to learn about three-point implements. I recently got a used carryall, the kind they sell at Tractor Supply.
I raised the deck and hooked it in place with a short piece of chain so I can raise and lower the hitch arms. However, the parts that raise and lower the deck which sit on top of the three-point arms are still in place and do somewhat restrict the movement of the arms side to side. So, when I went to hook up the carryall, I decided it would be easier if I turned the pins around facing inward instead of outward, as I have seen suggested on other posts here.
Now, I was in a bit of a hurry to get to hauling firewood, so when one pin came loose pretty easily and the other did not, I decided that I would try it with one pin pointing in and one out. I found that with this set up I can pivot the carryall into position to bring the outward facing pin into position on one arm. Then I hook the top link, and finally pull the other arm into place on the inward facing pin. I've used it this way for about a week.
Here's my question: is there anything wrong with doing it this way? Will I be creating some problem down the road? It doesn't seem to bind or look cock-eyed. Anyone else done this?
One other question: What do you use for lube on the balls at the ends of the lift arms? Oil, grease, PB Blaster? Seems oil or grease could attract and hold dirt and crud, and grease wouldn't work in there very well.
Thanks!
Thanks!
