3 point hitch O ring.
   / 3 point hitch O ring. #1
Neat 1500
Platinum Member
Queensland,Australia
Only a YM14 MkII
My 3 point ( on the 1500 ) wont hold its ground any more, even closing the valve it still drops so i am assuming my O ring is leaking past. i want to pull it down but have it together quickly. i have a fairly comprehensive O ring kit so i should be OK, question is does someone remember what size it is? i take it shes the round type and not a square one? i have looked at the Hoye diagrams but no specs ( an O rings an O ring!) might even have 2 on it. looks to be just a matter of unbolting the top section and lifting it off?
   / 3 point hitch O ring. #2
The oring on the lift cylinder is a P55. They are a JIS (Japanese Industrial Standard) size oring which is not very common here. It is actually a 54.4mm ID.
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
2024 Rhino 4155 Batwing Mower (A53473)
2024 Rhino 4155...
CONTACT INFO (A53084)
40' High Cube Multi-Door Container (A50123)
40' High Cube...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
Unused 2025 MS380 Mini Track Loader Skid Steer (A51691)
Unused 2025 MS380...
