3 point hitch lift not working - 67 Ford 3000
   / 3 point hitch lift not working - 67 Ford 3000 #1
Harley1283
Statham, GA
1967 Ford 3000 Diesel
I have a 1967 Ford 3000 Diesel Tractor - the 3 point hitch hydraulic lift does not work - I removed the lift cover and found that both suction and return line filter screens needed cleaning, the suction filter was really clogged with sludge. I visually inspected all accessable components and reassembled, installing new o-ring seals where indicated. The lift still doesn't work. I did a pump pressure test as prescribed by the manuel and pump pressure was above 2500 psi. Any ideas on what to check next??
   / 3 point hitch lift not working - 67 Ford 3000 #2
sometimes there is a bolt that needs to be loosened to relieve air (bleeder, kind of like on brakes), not sure if this is the case for your particular tractor, I'm sure someone will know more.
   / 3 point hitch lift not working - 67 Ford 3000 #3
this thread is a bit old but saw it in a search and thought of two things it could be based on my recent work on my 69 3400 3ph hydraulics:
- any chance the lift arm to lift piston shaft ("dogbone") fell down as you were installing the lift cover? If it did, things could be working properly, but the arms would never raise. I think the arms have to be kept in the down position during installation to prevent this, so if you were using them to help grip it and get the cover back into position it could have slipped out and rotated down.
- did you check all the position and draft control linkage and remove and inspect the check and unload valves? I have read that the unload valve o-ring is a common cause of problems on these tractors. If the check valve was way out of adjustment I believe it could prevent fluid from getting in the port that allows the lift cylinder to fill.
   / 3 point hitch lift not working - 67 Ford 3000 #4
Ford 3000 tractor the three point will not raise need help....please
   / 3 point hitch lift not working - 67 Ford 3000 #5
Welcome to TBN. What can you tell us about the history? Was working then quit? Repair attempted then quit? What have you done to date. More help from you equals better responses from us.
Jim
   / 3 point hitch lift not working - 67 Ford 3000 #6
Yep, I'm with Jim. Need more details.
   / 3 point hitch lift not working - 67 Ford 3000 #7
Look in the manual for pump bleeding procedure. My manuals are out in the shop and it's late.
INSPECTION (A51573)
INSPECTION (A51573)
2005 INTERNATIONAL 4300 CARGO TRUCK (INOPERABLE) (A50854)
2005 INTERNATIONAL...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
2006 KENWORTH T300 SERVICE TRUCK (A51243)
2006 KENWORTH T300...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
Unused 2025 CFG H15R Mini Excavator (A49461)
Unused 2025 CFG...
