3 point hitch jumps up and down
   / 3 point hitch jumps up and down #1
Logger Laurier
Hectanooga
Kioti DK35
Greetings all. I have a Kioti DK35 which I like very much. My problem is as follows: When the 3 pt hitch has a load on it, which is all the time as I am a professionel logger and use a Farmi winch, the system jumps up and down all the time, shaking the whole tractor. The only time it stops is when I turn the speed control to LOCK position. This is very problematic, as in LOCK is ok for some jobs but not others.
Any thoughts?? Thanks!
   / 3 point hitch jumps up and down #2
Logger,
Is this when the 3 pt is fully raised or in any position with a load?
If you raise the 3 pt hitch loaded and shut the tractor off, does the 3 pt hitch leak down?
If yes it would indicate that there is a leak in the lift system. Potentially the seals on the lift cylinder, possibly some valve also.
   / 3 point hitch jumps up and down #3
I'm with oldnslo, sounds like a leak either in the cylinder or the valve. The jumping is the "position control" trying to maintain a certain height dependent on lever location.
His explanation of the loaded 3pt settling when the engine is off confirms that leak.
Any position, with or without a load. That said, it doesn't always do it, but most of the time. Yes, it lowers by itself with tractor shut off. Have you changed these seals before? How hard a job is it? Big tear-down or simple access?
   / 3 point hitch jumps up and down #5
I have never worked on a Kioti but on most models you have to ether remove the top of rear differential transmision assembly or possibly the back to access the lift cylinder.
If it jumps or jerks with no load that would indicate a pretty large leak. Is there a chance some external linkage got bent from a tree branch?
Thanks all for your replies! Starting to make sense.
I don't see any bent linkage, but would have to remove wheels to see better. That scenario is a real possibility, for sure. I had a tree branch take out my hydraulic filter one time...broke the filter housing. That was an experience! LOL
Thanks again.
   / 3 point hitch jumps up and down #7
Jumping when the lock is off, but not when on would steer me more like a valve either being stuck due to debris or a seal/s or o ring/s leaking. Could be the 3ph control valve or even a relief leaking.
   / 3 point hitch jumps up and down #8
I know this is old but have a look at adjusting the MLS valve.
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
HAY KING RENOVATOR (A52472)
HAY KING RENOVATOR...
