3 Point Hitch Implement Fabrication
   / 3 Point Hitch Implement Fabrication #1
Dascro
SW Pennsylvania
Kubota B7610, Cub Cadet 1450
I am mounting a spray tank and boom to a three point hitch platform that I fabricated from angle iron.
My question is... Does the upper link connection point have to be in the same vertical plane as the lower link arms connection point? I know they are on most 3 PH hitch implements, but not sure if its absolutely necessary.
Thanks in advance for any help.
   / 3 Point Hitch Implement Fabrication #2
No, it does not "have" to be, but it "should" be. But withe a sprayer you won't need to adjust the top link once it's level so go for it:D
So aside from having to adjust the top link length when attaching and leveling the sprayer, do you believe having the three connection points not in the same vertical plane would introduce unnecessary or damaging forces to the tractor?
Thanks,
Dave
   / 3 Point Hitch Implement Fabrication #4
The top link mount ain't gonna care.There are not hard and fast dimensions for three point equipment,more like generalizations.
   / 3 Point Hitch Implement Fabrication #5
Well, there IS a standard, it's just not followed well... Look HERE for the ASAE standards for quick-hitches.
   / 3 Point Hitch Implement Fabrication #6
If you fab something like a boom pole, the height of the top link hole becomes important (the distance from the lower pins to the point where the top link attaches to the boom). The 3 point hitch is actually a mechanism called a "4 bar linkage". The tractor forms one bar, which is fixed; the upper joint of that bar is where the toplink attaches to the tractor and the lower joint of that bar is where the lift arms attach to the tractor. The remaining three bars of the linkage consist of the toplink (bar 2), the attachment (bar 3), and the lower lift arms (bar 4).
When I first got my tractor, I made a boom pole and didn't pay attention to the measurements. The geometry wound up wrong: I had made the attachment points on the boom too close together (vertically). Bar 3 was too short. The boom would tilt downward when I raised the 3pt hitch!!! Oops. Embarressing, since I am a mechanical engineer. So I laid out the geometry on Autocad with different permutations: bar 3 longer than bar 1, bar 3 shorter, etc. For a lift pole, bar 3 should be equal to or longer than bar 2....measure the distance from the point where the toplonk attaches to the tractor, to the point where the lower lift arms attach. Make the mounting holes on the implement equal to this dimension if you want the implement to remain in the same vertical plane (adjust the toplink as necessary). Make this dimension longer if you want the implement, like a boom pole or mower, to tilt upwards as you raise the 3pt hitch.
Thanks for all the informative replies. This continues to be a great forum because of the helpful people.
Thanks,
Dave
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
UNUSED RAYTREE RPRB72-72" POWER RAKE BUCKET (A51248)
UNUSED RAYTREE...
2025 JMR Stump Bucket Skid Steer Attachment (A51691)
2025 JMR Stump...
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
