3 point hitch/ auger
   / 3 point hitch/ auger #1
MrJonsson
Denver, Co
CubCadet/Yanmar Sc2450
Hi,
I'm new here. I have an Sc2450 and am looking for a 3 point hitch and an auger (post hole digger) that will work with this machine.
Any help would be greatly appreciated.
I don't know, I am having a hard time finding any info regarding this tractor and what accessories fit it
   / 3 point hitch/ auger #5
I'm pretty sure you will have to get the 3 point hitch from the dealer if you didn't get it when you bought the tractor. It looks like it's optional when you buy the tractor.
The 3-point is a limited cat 1. When looking at a post hole digger, I think the longest auger you will be able to get is possibly a 42" unless you can raise the angle of the post hole digger to allow for a 48" auger.
There's a post on tbn, I can't find it now, that lists the post hole diggers that would fit the SC2450/2400 and other sub compact tractors. I have a Woods PHD35 with a 9" auger that's 42" long and I have about 4" of space between the ground and the tip. the phd has a couple of holes to adjust the height/angle of the phd to allow for a longer auger.
You can always turn the pins to the inside when you mount the phd to help with the limited width of the 3 point.
Here's the specs on the tractor.
http://www.yanmartractor.com/pdfs/sc2450.pdf
Here's some attachments that come from Yanmar
http://www.yanmartractor.com/attachments/index.html
   / 3 point hitch/ auger #6
talk to your dealer I do know they made one to fit it in 2008
also everything attachments sells I dont remember the brand but they make a special one for the limited class 1
I believe woods makes one special for the limited changes the angle to get more clearance
   / 3 point hitch/ auger #7
We make post hole diggers for subcompact tractors and offer them with auger sizes from 4" to 12". You'll find them on our website here. They use a standard 48" long auger with a 2" output shaft.
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
2019 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2019 JLG ECOLIFT...
2013 Chevrolet Sonic Sedan (A50324)
2013 Chevrolet...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52128)
2017 Rogator...
