3 point boom sprayer question
   / 3 point boom sprayer question #1
plmojn
N.E OHIO
I am going to get started building a boom sprayer. Question is I see TSC has horizintal leg tanks and applicator tanks, would the horizintal leg tank work for a sprayer? What would be the difference? I am planning on a 65 gallon tank. Thanks for any advice
   / 3 point boom sprayer question #2
I would think as long as the tank has the necessary ports it would be fine. Many sprayers use the horizontal leg tanks. I think the reason is it saves having to have or need rounded cradle for the tank.
Why 65 gallons? Is it for a small field? Depending on what you will be using it for consider have a port for hand held sprayer. That is great if doing a lot of spot spraying. If you do have plenty of hose on it so you can park and walk a few feet. Have a neighbor who put a water faucet on his. If you do such be sure you do not use that hose for water.
   / 3 point boom sprayer question #3
I also used the TSC 65 gallon tank and the sprayer has held up pretty well. You can click on my signature link to see how I put ours together. I'm getting ready to assist my neighbor in putting one together for his New Holland.
If I can help further just shout
I will order the 65 gal. horizintal leg tank. Wasnt sure if the applicator tank had baffles in it, or there would be some other reason. Thanks for the great info on your link pine ridge.
   / 3 point boom sprayer question #5
How many acres do you plan to cover? We normally put 5-10 gallons of water per acres so if you use the 65 it would only cover 6-13 acres. Just a suggestion of course, but it will depend on the tractor you will be using.
If you plan to spray quite a few acres, you may consider a bigger tank.
   / 3 point boom sprayer question #6
Ours is filled twice for 6 acres. but it gives me a reason to go back to the fridge for another beer. :rolleyes:
Glad the link helped you.
   / 3 point boom sprayer question #7
That is a very good point of course. I normally carry a cooler with me, although I rarely drink anymore.
We have about 400 acres now that was once farmed so we have a 250 gallon tank. I plan to re-do this spray rig this spring because I really could use it.
My hay fields are 2@7 & 2@10 acres with 50 acres in pasture. I would use a 50 hp tractor.
   / 3 point boom sprayer question #9
Now that I'm a little older I don't drink anymore, I don't drink anyless either. :eek:
I'm helping a neighbor put a sprayer together. He'll be using a 120 gallon tank.
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
1999 Ford LA-9000 Aeromax Godwin Steel Dump Truck (A52384)
1999 Ford LA-9000...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
