3-Point Hitch 3-Point Backhoes
   / 3-Point Backhoes #1
KENB
CENTERVILLE,TX
MAHINDRA 4110, Ford 2N
I spoke to my Mahindra dealer regarding the purchase of a Mahindra 509 (Bradco), since I hear it is an awesome unit. But my dealer is encouraging me to go with a 3 point backhoe instead . Possibly the Bradco 3 point. He says he would go with the 3 point over the subframe because the subframe 509 is expensive. I told him my concern of damaging the tractors by using a 3 point backhoe, and that is why I was interested in the subframe mount. My dealer says that since I have a loader (it is the ML112), that there is no problem putting a 3 point backhoe on my 4110 /forums/images/graemlins/confused.gif.
Recently, I have came across a deal with on 3 point backhoe (Kelley B30), for around $2k, so I was considering buying this unit for my 4110. I would be using it for things like digging up stumps, cleaning out a drainage canal/ditch on my property.
I know I have heard of guys splitting their tractors in half with a 3 point backhoe, but I did not know that a FEL would keep that danger from happening. Has some logic to it because of the weight at the front with the frame and all of the FEL, but I am still skeptical. Any feedback would be appreciated.
   / 3-Point Backhoes #2
Baloney... I've had 5 different backhoes on different machines. All of the ones on other than my New Holland TN (heavy duty Cat II hitch) were subframe mounts. each of these mounts tied into the loader frame making for very rigid assemblies. I would not run a 3pt backhoe on anything smaller than a Utility tractor with a Cat II hitch. The loader itself will be of no help as the place where the tractor ususally splits is behind the loader frame. I have seen several split tractors at my dealers over the years from using 3pt backhoes on small machines. The subframe is the way to go. LaryRB had a subframe Bradco on a Mahindra that worked very well. You could PM him and ask about it. He did a lot of research before buying it. I used the hoe and was impressed with its capabilities.
Andy
   / 3-Point Backhoes #3
I have a small 3pt backhoe I use on a Ford 3000. The problem I have is as you dig the bh trys to lift itself up because there is no down pressure on the lift. There is a place for the subframe to mount on the hoe and I am in process of building a subframe and mount now. I want to buy a 2015 hst and this hoe is small enough to use on it with a mount. Just my opinion GO with the mount regardless of tractor size if for no reason but saftey.
   / 3-Point Backhoes
Well, I've messaged in the past with LarryRB on his backhoe. Yes, he has the 511 and is impressed with it. I would be impressed also, but I don't know if my wallet would be too impressed. 8-10k for a subframe backhoe is a considerable chunk of change. I understand the concept of you get what you pay for, but to spend 8-10k on a backhoe??....well ... you better have alot of work to be done with it in order to justify that cost. The 3points are much less expensive, and besides you can find a used one, whereas finding a used Subframe backhoe that fits my Mahindra would be next to impossible. I don't think LarryRB is going to be selling his anytime soon! /forums/images/graemlins/grin.gif
   / 3-Point Backhoes #5
KenB - I'm running the subframe mount on my Wood's BH and for me - if I would have bought the 3pt, I would already have my tractor in for some serious repair work. I grub a lot of stumps out with mine and always look for ways to get the bucket in between large roots, looking for every bit of leverage I can get to snap off a big root. To think of the stress and strain that a BH can create to not only itself but also the enormous stress that is passed thru the 3pt and the rest of the tractor. The Mahindras already have a substantial frame under them and the sub frame mount just seems to take advantage of that design. I can see where a FEL mount adds to this rigidity but it has nothing to do with the 3pt hookup. Everything that backhoe does relies heavily on those small 3pt arms and while I'm not an equipment engineer, it just doesn't give me a lot of faith as far as the longevity of the tractor. A sub frame mount could run you as high as $850.00 more. It is worth every darn penny to me and that will be cheap compared to replacing a casting plus labor. Another point to think of and it's not in even using the backhoe for it's intended use but while in transport. Ever go down a path and hit a small pothole and you swear something just had to break somewhere? Do you want that shock passed to the 3pt hookup? Almost 1,000 lbs is hanging out there unsupported for that instant. Just the thought makes me cringe. The only "con" that I can think of is that it will be by luck if you ever sell the BH and try to find a perspective buyer with the same tractor. I don't think the subframe mount is readily adaptable to just any tractor but that is not to say that the backhoe is useless at that point. The next guy just has to pop for the mount for his tractor. Maybe your dealer just doesn't want to spend the time installing the subframe mount. I have too much money invested in my "toys" to take unneccesary chances. Hope this helps a little Ken.
   / 3-Point Backhoes #6
</font><font color="blue" class="small">( I understand the concept of you get what you pay for, but to spend 8-10k on a backhoe??)</font>
You can get a lot of hoe work hired for $10K. In my area you can also find older TLB units for that kind of money that are in good shape to run for the kind of jobs you describe, but wouldn't hold up to the 12 hour a day work that the guys who run the hoes for a living require.
   / 3-Point Backhoes #7
Ken , I have a 2810 HST with a 3375 Hoe on a sub frame and don't think I would be happy with a 3 point set up.
I got stuck real bad last year and had to use the BH and outriggers to pick up the back of the tractor and move it around 180 degrees. I then picked it up in the air with the BH so I could get planks under the tires. I am not sure how a 3PT hoe would stand up to that kind on abuse. With a sub frame it was a piece of cake.
If the 509 sub frame is like the 3375 , Dayco has done a great job. I goes on and off easy and you don't lose any ground clearance.
A lot would depend on what and where your digging, for the type of digging I do , I would not be happy with a 3PT hoe.
Dave in NH
   / 3-Point Backhoes #8
ken i had a 3pt mount hoe on my 2810 IT WAS A PAIN IN THE A**
to line up and mount plus the large chance of body damage to you or tractor. Dr bills will easly use up any savings. I bought the sub frame kit and it was wroth every cent in time and safety .On my 4110 i got the 511 w/ subframe and it makes me smile every time
   / 3-Point Backhoes #9
KenB,
Let me answer some of your concerns or at least what I think about the situation. You're getting a 509. I do not know what a 509 needs for pump capacity so we'll skip this part.. There is no way in ****, regardless of what hoe brand and, or it's cost where I would mount on a 4110 3 pt system.. I bought my machine from Johnsonautomotive. who is a frequent visitor here. They, are more than well versed in backhoes and Mahindra's in particular. I have never heard them ,ever, suggest a 3pt, especially on a 4110.. Yes, I had the 511 and it was big and powerful.. That 511 could whip the 4110 all over the place like a kids tonka toy if you let it. The 509 can too. Class one 3pts aren't enough strength to hold up and operate any hoe (I'm talking the 4110 only) I have operated AndyMA's 75D w/3 pt Woods 10 ft hoe.. The point being, one of his 3pt lift arms would equal at least four on a 4110. He also has some serious cross bracing added on which is similar to a four point rear system in a race car.. Those cross braces alone are a minimum 3/4" or 7/8" thick or even thicker.. The subframe is the way to go, whether a Bradco 509 or any other brand... I am afraid that buying a well used hoe for 2 grand, making it a 3pt, then using it, will only hurt both machine and the newly mounted hoe, and in a very short time, what will you have then? The other thing is, I know that Johnson auto can and has in the past, got modified subframes and does on rare occassion use a local welder who modifies or makes a custom frame for them... The cost wasn't out of line either...
   / 3-Point Backhoes #10
I would not recomend it, we repair alot of tractors,(non mahindra) other brand that people have put 3 pt units on. tractor broken in half, 3 pt mounts torn off, broken axle housing on the fords where the lower 3pt arm attaches to the axle, etc. If you install a non " Mahindra" ,or any other brand non OE supplier on that specific brand (Deere on a Deere etc) it will void the warranty if it breaks. If you do break something your going to go after the backhoe manufacturer for the repair not the tractor company. The subframe on the Mahindra/bradco 509 is and excellent setup, strong, easy on and off etc. The price of the Mahindra/bradco should not be that big of a difference of buying a new Bradco 3pt mount 509. At least in this part of the country. There is a dealer in the area selling red bradco's on the mahindras up here a little cheaper, gets them the sale sometimes, but have sold a few of those people subframes after the fact due to they where not happy and the dealer told them it was not needed and did not to sell them one.
I will tell anyone who comes in the door what ever brand of tractor you buy, spend the little extra and get the frame mounted hoe.
Scott
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
