3-Point Hitch 3 point backhoe
   / 3 point backhoe #1
ergoman
I purchased a tc55da 2wd a month or so ago. I was offered a backhoe from my uncle that fits on a 3 point hitch. I noticed that the NH backhoe uses a subframe. The backhoe is about the same size as the bh recommended by the nh dealer, 12 inch bucket. Im sure that it doesnt wiegh 2000 pounds. Its off a machine like a case bucket/backhoe combo and has the three point hookups welded on. He's used it several times on his 75 hp tractor without any problems. has a pto pump on it that is almost new. He wants $500 for it but I'm not sure about the three point vs. subframe issue. I have 1000# of ford wieghts I picked up at an auction at .20 cents/lb. so could add those if I need to. Has a seat and controls etc.
Think it would work? Could it be plumbed to the tractor hydraulics? (I have one rear remote and a bucket)
thanks
   / 3 point backhoe #2
Even with the standard size of hoe that comes on compact tractors, there can be a problem with the tractors breaking into. That is the reason most manufactures offer sub-frame assemblies for compact tractors. It sounds like this is an even larger hoe. The forces that are generated by using a hoe are enormous. With that large of a hoe, I would be afraid to use that size of hoe on it with a sub-frame. It sounds like you don't have a loader. If you don't it isn't advisable to mount a backhoe on it. It isn't so much for the weight as it is for stability when using the backhoe. If you do a search you will find more than you want to read about using a three-point backhoe verse using a sub-frame mounted backhoe.
   / 3 point backhoe #3
I have run a woods 7500 3 pt backhoe without any problems for 800 hours.
   / 3 point backhoe #4
I think it all depends on how you use the BH. I have a 3pt Woods 7500 on my TC33D. The soil here is mostly sandy, and I don't use the BH to dig out stumps of any substantial size. If you use a BH much, it's not hard to tell when you putting stress on your machine. A subframe is a good idea, but with common sense, it's not a absolute requirement. If you're hard on equipment, or want to push your BH to the limit, get a subframe.
   / 3 point backhoe #5
Not every three-point backhoe breaks every tractor, but you are taking a chance any time you install one on a compact tractor. Do a search back through the archives and look at what happens when one has had enough.
2002 Trotwood Trailer (A50515)
2002 Trotwood...
`2021 CATERPILLAR 246D3 WHEELED SKID STEER (A51242)
`2021 CATERPILLAR...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2012 RAM 5500 (A52472)
2015 Ford F450 Service Body (A47384)
2015 Ford F450...
40' CONTAINER (A51244)
