3-Point Hitch 3 Point Arms Stuck
   / 3 Point Arms Stuck #1
gilbertmsg
Disputanta, VA
2007 Kioti CK20
Have CK20 gear, when starting tractor today (38 hrs), noticed the 3 point arms were in the highest postion. Moved the lever to down to the lowest postion and arms did not move. Tried to push them down with no success. Any comments would be appreciated. Close to 50 hrs service, but still would like to use before having service completed.
Eddie
   / 3 Point Arms Stuck #2
Eddie
Check your drop rate adjustment, usually a knob under your seat. Turn it in/out to adjust how fast the tph lowers. If it's all the way tight, it won't drop at all.
Thanks Rob, I'll check in the morning and post the results.
Eddie
Rob, thanks for the reply, that was the fix. Don't really know how it happened because I have not changed anything. Guess it could have come from vibration.
Eddie
   / 3 Point Arms Stuck #5
Could it be the same problem I had? I learned about this phenomenon the hard way, like you. Spent an evening thinking my new tractor was somehow broken. Got the magic trick then started the investigation. Turned out, my young kids had been sitting on the tractor some days before and had turned every switch, lever and knob. This was one I missed. Hope your investigation proves as innocent! Good to hear you got the problem fixed.
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
2013 Ford Transit Connect (A47384)
2013 Ford Transit...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
2023 Spartan RT - HD Zero Turn Mower (A50514)
2023 Spartan RT -...
2015 John Deere 5085M (A50120)
2015 John Deere...
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
