3 point adjustment knob problems.
   / 3 point adjustment knob problems. #1
Nolo263
Bronze Member
1986 Ford 1710
I have a problem with my 3 point adjustment knob. Basically it does nothing. It will not slow down or speed up when lowering 3 point. I already changed seals.
   / 3 point adjustment knob problems. #2
Does it turn really easy? The knob may need tightened on the shaft (flow control needle). I think there is a center nut or screw that may have worked loose on the adjustment knob. Do you need it to go faster or slower? If you need to make it go slower, you can make a quick temporary adjustment by loosening the big nut at the cover plate about 1/4 to 1/2 turn and then turn the knob clockwise until you get resistance and then try a little more pressure on the turn to get it to go another small amount to slow the flow. If that works be sure to retighten the big nut at the cover plate.
Thanks I will try that! I am trying to get it to go slower.
2008 John Deere 5203 Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2008 John Deere...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A50324)
2004 Fleetwood...
2019 International DuraStar 4300 2,000 Gallon Water Truck (A50323)
2019 International...
Two Post Car Lift (A50121)
Two Post Car Lift...
2014 Volkswagen Passat TDI SE Sedan (A50324)
2014 Volkswagen...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
