3 Phase
   / 3 Phase #2
</font><font color="blue" class="small">( /forums/images/graemlins/confused.gif )</font>
So am I, did you want to elaborate on that or was that it? /forums/images/graemlins/grin.gif
   / 3 Phase
the sig: does not work corrctly...........
I some how lost 1/2 of this post???
What I was asking about was
I now have 220 in my garage and would like to buy a older used welder that is 3 phase
I need info on a Inverter to change the 220 to 3 phase
There is a place in Cleveland Ohio that buy's closed factories
and has a lot of (((220/440/480)) equipment
thanks
Doug
   / 3 Phase #6
Lose the spaces between {image} and the url
Should be {image}http://www.tractorbynet.com/forumfiles/393411-greyhound.gif{/image}
Not {image} http://www.tractorbynet.com/forumfiles/393411-greyhound.gif {/image}
I used { } instead of [ ] so you could see the code.
   / 3 Phase #7
If all you want is a welder, I'd just get 220 1ph welder. Farmers use rotary phase converters for high hp ap[plications like feed grinders, augers and conveyors etc. I wouldn't think there wouldn't be much advantage for3ph welder unless you do a lot of gouging.
   / 3 Phase #8
Rotary phase converters dont do real well on a welder depending on the welder. If its an old generator/driven dc welder where an electric 3 phase motor drives a dc generator for power it will work. as for machine tools a simple rotaryconvertercan be made from a large 3 phase motor with 1/3rd greater amount HP rating as your largest motor. The trick is to wire 220 to one leg of the slave motor and then a switch to motor of the machine and a 220 to one of its legs. Then run your other 2 legs off the slave motor to themachines moter. All youhave to do is use a 1750 rpm 110 motor to spinn the slave motor up to speed and add power. It generatsa the other 2 legs for your machineto run off of. My old machinist teacher had us build one forhis home shop. Its slightly inefficeint butworks.
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
Bell B30E 30 Ton Articulated Dump Truck (A52377)
Bell B30E 30 Ton...
2008 Ford F-350 (A53422)
2008 Ford F-350...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
