KYErik
Platinum Member
- Joined
- Dec 2, 2005
- Messages
- 904
- Location
- South central IL
- Tractor
- 1977 AC 7000, 1980 JD 2840, 1963 Case 930, 1963 Ford 4000, 1943 Case SC, Case 530CK backhoe
I have an old white westinghouse 1150 rpm 7.5 hp 3 phase electric motor that I am running on 220v with an factory made static phase converter (simply a large bank of capacitors with a magnetic switch controller that starts the motor turning and then kicks out).
I am running a home made bandsaw mill with this motor. The motor starts fine, but I am needing more power from it when I cut 20+ inch logs.
Here are a few questions for the electricians/electrical engineers:
1. About how many HP is this 7.5 hp 3 phase motor really developing since I am running it on 220v single phase?
My dad has a 5 hp single phase low rpm motor that I was thinking of swapping onto the mill- but would this yield any more power over what I have now?
2. I also have 2 more 7.5 hp low rpm 3 phase motors (I don't recall the brand names right now- but they are identical to each other). Could I run one or both of them as rotary converters and supply enough power to the motor on the bandmill's 3rd leg to get it up near the 7.5 hp nameplate rating?
So, my goal here is to determine how much hp I am getting from the 7.5 hp 3 ph motor on the bandmill and try to figure out how to get more from it or if I should just switch over to a 5 hp single phase motor.
3. Related question- is this 3 phase motor running at nameplate rpm when running on single phase or is it actually turning slower since the waveform is different?
